DVD directly on top of amp?
Discussion in 'AV Receivers & Amplifiers' started by avmunster, Apr 7, 2003.
  1. avmunster
    avmunster
    Aug 12, 2002
    198
    Hartlepool
    +5
    I have just enough room in my cabinet - but would have to sit
    DVD ontop of the amp. Will this cause heat/interference?
  2. Garrett
    Garrett
    Apr 21, 2001
    33,159
    2
    167
    The best thief you’ll never see.
    +4,375
    I would have thought it better to have them the other way round. As to the height, does you manual give heights for air movement round the amp if not I would think at very least 1inch if it gets warm.
  3. Grimley
    Grimley
    It may not cause interference, but it will in most cases cause a fair amount of heat, which will not do either unit an awful lot of good. Simply, I wouldn't recommend it (speaking from experience).
  4. rigman
    rigman
    Dec 14, 2000
    2,760
    83
    East Yorkshire
    +59
    It is amazing how the installs shown in HCC always have all the gear crammed into cupboards. I wonder how long they manage to use if for before it all overheats and shuts down.
    My gear is on very open racks with lots of breathing space for all of the components but I dont need the radiator on in my cinema room even during the winter due to the amount of heat given off.
    Sometimes if the film finishes early enough I just have to end up watching two films as it is too cosy to leave.
    Darren
  5. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    If you have a light DVD player (Like the new Pioneers) it might help having the amp on top of the player as it would give it more rigidity.
    Subject to adequate breathing space of course
  6. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    These installs aren't designed to sound good but to appeal to "Footballers wives" where appearance is everything. The more appealing an install looks, the more likely the installer is to win an award then more footballers wives will use them and perpetuate the myth.
    If the electronics burn out they will simply be replaced, as it saves dusting the units, but how can loudspeakers that are designed to give of their best with a metre of free space behind them, perform when stuck inside a box.
  7. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    Had my DVD on top of the amp and the feet "burnt" itself into the top. Now that the amp is on top of the rack it looks not-so-nice.
    Wouldn't recommend it due to the heat dispersion.
  8. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    I think my amp would crush my pioneer, great player but feels like it was made by Matel!:D You have the 545 too don't you Ian?
  9. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    Not any more as I have the 646 now. I remember reading in one of the reviews that this particular model sounded better with a weight on top of it.
  10. Bogside
    Bogside
    Sep 20, 2002
    3,030
    Stockport (ex Derry)
    +380
    Lol:rotfl:
