DVD Dilema
Discussion in 'Blu-ray & DVD Players & Recorders' started by baldybonce, May 18, 2003.
  1. baldybonce
    baldybonce
    May 6, 2003
    931
    28
    Brighton,England
    +38
    I am very new to the home cinema world and am a bit confused on which dvd player to go for :confused: I have about £800 of my budget to blow on it, but as you all know there are so many out there to choose from.
    I was really impressed with Denons 3800 which would go well with my choice of 3803 receiver, then along came a demo of a Yamaha but unfortunatly have forgotten unit code:suicide:
    Has anybody got any views on what is good for this amount of money. It needs to be multi-region and am not sure if Denon is as keep forgetting to ask...
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +13
    Hifi junkies sell the 3800 for £759. I've got a late build one & it doesn't display any of the problems that earlier versions (according to previous users here) did.
    They are hard to find now but the 2900 should be out here soon.
  3. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,896
    71
    50 Rue St Georges, Paris.
    +27
    My DVD-3800 works perfectly too. :)
    If that's your fancy don't be afraid to buy and try.
  4. baldybonce
    baldybonce
    May 6, 2003
    931
    28
    Brighton,England
    +38
    Is the 3800 compatible with all region dvd's?, and are there any other makes I should be looking at?
  5. Rasczak
    Rasczak
    Apr 3, 2002
    21,221
    Argyll
    +2,268
  6. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +13
    The dealer you choose should be able to multi region & PAL progressive update your Denon 3800 before they supply it.
    If not you can get the firmware update & do it yourself at The Denon DVD-3800 unofficial website
    Other players upto this price bracket that seem popular here are the Pioneer 757 , Philips 963SA & Arcam DV88+ (which is a bit above your £800 budget). Just do searches on them to see what I mean.
