DVD delta volume (FAO MIKEYBOY)
Discussion in 'General TV Discussions Forum' started by ubik, Feb 17, 2003.
  1. ubik
    ubik
    thanks mikeyboy,
    how do you "upping the Delta volume input for the SCART socket I use." ??
    in relation to the dvd volume high problem I have
    cheers
  2. mikeyboy
    mikeyboy
    On my 9617 you can configure the input volume from each EXT source using the menus. I had DVD to EXT1, Satellite to EXT2 and video to EXT3 - the volume was fine when using the last two but very quiet for DVD. I checked the menu settings, all the EXT inputs were set with the volume in the middle of the available range - I set the EXT1 volume to max and now when I switch to DVD the sound level is the same as the other inputs (also my ears don't bleed when I switch back from DVD !!):clap:
