DVD Decrypter Help
Discussion in 'PS Vita Forum' started by dts borg, Aug 29, 2005.
Tags:
  1. dts borg
    dts borg
    Sep 5, 2001
    577
    Hornchurch
    +8
    I have saved a few movies to my PC using DVD Decrypter with no problems but today I put in The Incredibles R1 and found I could not use the Stream Processing tab. Do I need to change any settings or is this some kind of anti copy protection :confused:
    Thanks in advance..... ;)
    Been following this Guide
  2. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    36,435
    +6,220
    Use this guide here instead. If you're using PSP Video 9, go here
