DVD Decrypter/backup help
Discussion in 'Desktop & Laptop Computers Forum' started by Loafer316, Jul 8, 2003.
  1. Loafer316
    Loafer316
    Apr 8, 2003
    330
    I'm backing up some kids film on my little sisters pc so she can watch them w/o using the original dvd. Anyway i followed the guide and backed up the dvd in IFO mode....ran it through IFO EDit. However when i play it through Powerdvd the film stops after a certain amount of chapters! and you can't select further chapters...also sometimes the subtitles come out grabbled.
    Am i missing something in the decrypter settings? i first done this using the settings so that i only got one vob file...then i changed it so that it would split files to different vobid's eitherway i had the same problem.
    Any hints??
    I understand you can use ISO mode but that involves using a virtual drive which seems a bit long winded...would rather click a ifo file and start the movie only....thxs guys:confused:
  2. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    Have a look at the backup guide in the DVD section of the forums....that should help.
  3. Loafer316
    Loafer316
    Apr 8, 2003
    330
    Yeah i did but i ended up doing this!:laugh: :zonked:
  4. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    I know exactly what you mean....neither of those programs are exactly user friendly!
  5. salacious
    salacious
    Nov 2, 2001
    46
    Scotland
    I have no idea if this is related but PowerDVD is limited to playing 2GB files. Depending on how you back up your DVD you can specify either merging to one file or multiple files. Make sure it is on multiple files.
  6. Loafer316
    Loafer316
    Apr 8, 2003
    330
    thxs m8...that may have done the trick...i tried backing up my The Recruit and split the files at 2gb and now it works fine....although subtitles are still in this mumbled green colour....let me test out a few others.
    thxs
  7. Threadkiller
    Threadkiller
    Aug 23, 2002
    63
    I'd use Iso mode and daemon tools. it negates the need to run IFO edit, and plays normally I find its a lot easier
  8. pinkerton
    pinkerton
    Sep 26, 2002
    416
    Ealing (London)
    +3
    Try using smartripper instead, select backup mode so you can rip the whols DVD to a selected folder.
  9. John_N
    John_N
    The method I used is to use ISO mode and then use Daemon tools to mount the ISO image as a virtual drive. Then you can use any player you like to play it. Much easier.
