dvd conversion
Discussion in 'Blu-ray & DVD Players & Recorders' started by brin, Jul 12, 2019.
  1. brin
    brin
    Nov 24, 2009
    20
    I had a Toshiba dvd recorder on which I have recorded a lot of progs. The recorder died before I had a chance to finalise the discs. Can I reuse them by deleting the programmes and starting again. I have a newer Toshiba but I am assuming the read/write engine will be different. Any advice please.Brin.
  2. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,246
    +7,185
    Much depends on the disk format type.
    If they are rewritable discs you can use them again... after formatting.
    If DVD-R or +R, you cannot.
    But the likelihood is that you will be able to finalise in the new machine - given it is the same manufacturer.
  3. noiseboy72
    noiseboy72
    Apr 24, 2011
    6,327
    +1,930
    You may find it will still finalise the discs.
    If not, you could possibly use the blank space, but you cannot erase the recordings, as they are burnt into the disc.
    Finalising basically writes the table of contents so that the discs will play on any player. Up until that point there's a temporary file list written to an unused section of the disk that the recorder uses to create the finalised discs.
