DVD connections
Discussion in 'Blu-ray & DVD Players & Recorders' started by Steuart, Apr 19, 2002.
  1. Steuart
    Steuart
    I have seen a dvd with 5.1 amp and outputs. Can this be used with creative's 5300, 5.1 speakers for 5.1 effects?
    If so, how?
    Many thanks
  2. DaveP
    DaveP
    It's not uncommon for DVD players to have an on-board decoder to output the 5.1 channels. The few that have on board amplifiers usually come with there own speakers already supplied, or so I believe.
    Are you sure it has a built in amplifier and if so what is the output power?
    You need to establish just what the ouput sockets are on the unit. Then see if the Creative speakers have suitable inputs.
    DaveP
