Quantcast
Dvd Connection
Dfour
Usually (for amps without video up conversion) you would just use a RGB enabled scart from the dvd to the tv. For amps with up conversion AND a tv with componant inputs you could feed the amp a composite/s-video signal and then the amp would then output it as a componant signal to the tv.
Hope this helps :lesson:
zenden
Thanks Dfour for that I think my audio problem is comeing from my Argos switching box ,time to get a proper one thanks again.
Zenden
