DVD Connection Problem...
Discussion in 'Blu-ray & DVD Players & Recorders' started by DanAuber, Dec 28, 2004.
  1. DanAuber
    DanAuber
    OK - I'm hoping this is going to be simple
    I have a TV, a video, and a DVD player (Mico Espejo R311). The TV gets its channels via an aerial.
    How do I link it all up ?? - I have scart cables (the video has only one slot, the DVD player and TV have two slots for these)
    Thanks for help on this.
    Also - once it is wired up - how do I record onto Video and how do I record onto DVD.
    Thanks Again..
  2. miker
    miker
    Sep 25, 2004
    102
    Bournemouth
    +3
    aerial lead into the video and out into the tv
    scart from the dvd to the rgb scart of the tv
    set the tv to use rgb scart seletion on a channel such as 9 (if it can)
    and as an extra a scart from the video to the tv channel 0
    tune the tv channel 6 for the uhf from the video.
    i hope that helps
  3. DanAuber
    DanAuber
    Thanks - will give it a try
  4. subwayshowdown
    subwayshowdown
    as anybody used the digital coaxial on there mico , i dont seem to be getting any digital audio from this output , can you help?
