dvd component to VGA input?
SNICK
Established Member
Joined
Feb 4, 2001
Messages
793
Reaction score
29
Points
200
Location
UK
My DVD has component outputs. I've read somewhere, that if i get a 3 RCA to HD 15pin lead, that i can connect direct to the PC input on the back of my panny pw6. Is this correct ? Or will i need some kind of converter. If i get his cable, (for 25 quid) - this will save me on having to buy a component board at 4 times the price.
am i missing something here??
I think you will find that the Pw6/PWD6 can accept both RGB and YUV component thru' the VGA port.....all you need is the cable, from Lektropak's.
We've done leads for the 6 series, and others long before the 6, for exactly this purpose. I prefer to take a good quality VGA lead and modify it.
It's important to choose good quality leads, but custom building VGA plugs is a real pain! Hence, if you can't go for something such as a Better Cables lead, then best to pick a quality pre-made VGA lead and modify to suit.
All the best,
Dr John Sim.
Don't know if you've seen a lecktropaks lead, John, but actually they are just what you describe, and quite well done. Soldering a VGA plug is certainly not for the casual solderer.
Sony BRAVIA 9 Mini LED TV: The Best HDR TV EVER?
Back
