dvd combi or not ?
jtfab75
my niece is wanting a tv for her bedroom.i'm looking to spend between £150-£200.i'm not sure what to get her. a lcd 19" + on it's own or with a dvd built in (also must have freeview).
are the dvd players reliable and what make and model should i go for
thanks
rusty mechanic
hi mate
after reading alot of bad reviews about in-built dvd players not being reliable, i went against advise and got one for the conservatory. to cut a long story short, after a month the dvd broke:suicide: swapped it for a better spec lcd without a dvd built in and it's been faultless ever since. just something to think about before you buy. good luck
rusty mechanic
hi mate
i ended up getting a 20" LG from play.com for £270 but you can get just as good for less now. i was warned about the eject mechanism breaking on built in dvds and that is what went on mine.
Ben
I'm with Rusty, go for a seperate TV & DVD player. Afterall, you rarely see any well know brand TV/DVD combos, plus you've just about got the budget to get a decent set of both :thumbsup:
Spend £150 on the 19" LG M198WA, which can be found midway down this page - the offer's just expired, but they're normally pretty good at Richer Sounds, so it's certainly worth a try. That leaves you up to £50 to find yourself a decent (upscaling-?) DVD player :smashin:
Ben
I'll get my coat :D
(It was £180 the other day when I looked online).
Hisense U7H TV and T+A Solitaire T headphone reviews, AV/HiFi news plus, what is screen uniformity?
