dvd cleaning
Discussion in 'Movie Forum' started by coolgools, Feb 4, 2001.
  1. coolgools
    coolgools
    Does anybody know of good dvd cleaning kit?
    ideally it should clean both the discs and the player.
    coolgools
    RESISTANCE IS FUTILE...YOU WILL BE ASSIMILATED!!!
    [This message has been edited by coolgools (edited 04-02-2001).]
  2. PoochJD
    PoochJD
    Aug 28, 2000
    11,002
    Norwich
    +1,861
    Hi Gools,
    The kit you need, is free, available in every household in the land, and will last a lifetime - guaranteed!
    It's called "your hand"!
    Sorry, mate, couldn't resist that one. ;-)
    Seriously though, any normal CD-cleaning kit will do the trick. Stores like HMV and Virgin sell them for between £8 and £15. Just make sure they are DVD compatible though, as some aren't, and may cause damage to your discs or system.
    Hope this is of use,
    Pooch
  3. Napoleon
    Napoleon
    Jan 1, 2001
    I would recommend Brasso or Silvo.They give a hell of a shiny finish,which will impress the grandparents when they visit.
    I think B&Q are doing them in a special twin-pack!.
  4. General Skanky
    General Skanky
    Jul 28, 2000
    4,251
    71
    Colchester
    +43
    You should never need to clean a DVD player (alledgedly), as the optic is held within an enclosed unit, ie, dust free.
    The discs are best cleaned with fairy liquid.
    Simple clean and you're off.
    Save your money and buy more films. A lot of these accessories are junk.
    Douch!!......Wot's da madder, da CIA got you pushing too many penzils?
    Work: www.hughes-tv.co.uk
  5. Napoleon
    Napoleon
    Jan 1, 2001
    I used the CD Hydrobath discwasher today.
    The fluid supplied is for cleaning cd's/cd-i/
    cdrom.I guessed it would be okay for dvd.It worked perfectly,and played perfectly.It is a totally automatic cleaner.It spins the disc clockwise to clean,and then counter-clockwise to dry.
