DVD camcorder transfer to PC - How?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by deedub777, Mar 26, 2006.
  1. deedub777
    deedub777
    Mar 26, 2006
    13
    Help! Total newbie here. Just bought a Panasonic VDR-D150B and it has not come with any CDs . I'm chasing this up at the moment but in the meantime, can anyone advise me how to get the files onto the PC? This is what I have tried....
    1. Connected through USB, doesn't seem to recognise the camera (I don't have an SD card fitted either)
    2. Put the DVD (RAM) into the DVD drive on the PC - it recognises the DVD and shows me the following files: VR_MANGR.BUP, VR_MANGR.IFO and VR_MOVIE.VRO in a folder called DVD_RTAV
    Any suggestions will be much appreciated.:lease:
  2. jomike
    jomike
    Nov 5, 2005
    2,161
    116
    Frimley, Surrey
    +527
    Copy the .vro file to your PC and rename it to .mpg. If it is in 16:9, you will probably need to use a utility like fix12c to correct the aspect ratio.
  3. deedub777
    deedub777
    Mar 26, 2006
    13
    Cheers jomike!
    I got the picture across fine and the aspect ratio looks widescreen and plays OK with WMP BUT... no sound:oops: Any further suggestions?
  4. Brian110507
    Brian110507
    What application are you using to view your video - could be that the sound on your disc is Dolby and you don't have a Dolby codec for that application
  5. deedub777
    deedub777
    Mar 26, 2006
    13
    Hi Beejaycee,
    I chose Windows Media Player to view the video - is there another you'd recommend??
    Thanks,
  6. jomike
    jomike
    Nov 5, 2005
    2,161
    116
    Frimley, Surrey
    +527
    Download and install this AC3 filter and you should be able to play your videos in Windows Media Player with sound.
  7. deedub777
    deedub777
    Mar 26, 2006
    13
    That did the trick many thanks!
    :clap:
