DVD Burning
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Phatboy, Oct 5, 2003.
  1. Phatboy
    Phatboy
    Sep 13, 2002
    85
    9
    Cardiff
    Any advise on burning home movies to DVD? I use Studio * to create movies with menus etc which i burn using studio 8 to DVD. These work ok in my PC dvd drive but not my domestic dvd player. the first menu comes up but doesn't access the dvd! I also notice some poor quality in sound and missed scenes on final burn't dvd despite the pc preview being fine.
    Should i be using nero to burn or do i need the studio 8 updates?
    I don't use my movie pc on line!
  2. driver8
    driver8
    Nov 17, 2002
    191
    Malé, Maldives
    Hi Phatboy - not dabbled myself, but a colleague uses Ulead Movie Factory with good results.
  3. melliott1963
    melliott1963
    Nov 27, 2001
    427
    Ilford, Essex
    +4
    I too use Studio 8 to edit my movies, but have found the DVD burning capabiliy somewhat unreliable. I therefore save the DVD image to disk from within Studio (it is one of the options you can select), and then burn it onto the DVD using Nero. I've not had a problem doing it this way to date.
    However, it is always worth making sure you have the latest Studio update as they are released on a fairly frequent basis and it is quite a buggy piece of software.
  4. Phatboy
    Phatboy
    Sep 13, 2002
    85
    9
    Cardiff
    Thanks for info. I tried the image route in studio 8, but Nero expects a different file type. How do you know which pinnacle files to put into Nero DVD buring window?
  5. common
    common
    Mar 5, 2001
    1,384
    41
    Oxford UK
    +8
    I produced my first ever DVD last night after buying Uleads Movie Factory 2.0 deluxe - it was amazingly easy (inc capture) with some great results, I would recommend it
  6. mulder
    mulder
    Dec 9, 2002
    146
    I'm in an even worse state than you phatboy i haven't been able to burn any home video footage to DVD through pinnacle express rubbish the discs i copy don't play on anything including the DVD writer which produced them. I'm totally dis-heartend by it all. anyone got any ideas?
  7. MarkE19
    MarkE19
    Aug 10, 2002
    17,259
    Rainham Essex
    +2,403
    Have a look at www.dvdrhelp.com
    They have step by step tutorials for many software applications and lots of helpful advise.
    Mark.
