I have just tried to burn a TS file to a DVD using ImgBurn, but almost to the end of the burn process I got this error message (see attached screenshot):
I have used ImgBurn for the past couple of months now, bough some blank DVD-R discs a few months back and have been burning my converted home videos onto them, all without fail apart from one which ended up aborting mid way through, but this was due to the file being located on my external HDD which I accidentally moved causing the drive to disconnect from the laptop resulting in a partial burn. However, with this particular file I just copied the file over to a folder to my internal HD and then burned the disc, but at about 95% I got the error message and had to cancel and the last two remaining chapters hadn't been burned. No idea what could've caused this as I burned at 3x speed. Could've been a faulty disc or been scratched (can't see any scratches though). I suppose I could just try using a DVD RW disc and see if I still get the error.
