DVD burner won't recognise DVD-RWs
Discussion in 'Desktop & Laptop Computers Forum' started by the_gaffer, Jan 6, 2005.
  1. the_gaffer
    the_gaffer
    Hello all,
    I've recently purchased an LG 4163b IDE DVD burner that is multiformat and can accept DVD-R/RW, DVD+R/RW, DVD+R DL and DVD-RAM.
    I bought some good quality Sony DVD-RWs and the drive doesn't recognise them properly. It can tell a disc is in the drive but won't let me write to it.
    I thought by buying a good make, I would avoid this type of problem.
    I've flashed the firmware (worked on 3rd attempt) to the latest version.
    The drive is in an external firewire case connected to an XP Pro SP2 laptop.
    What could the problem be?
    How do I repair it?
    gaffer
  2. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,349
    83
    +193
    What Writer software are you using ? I'm using Nero and I have a NEC2510 adapted to Firewire and that works fine using XP SP2.
  3. the_gaffer
    the_gaffer
    I've got Nero 6 OEM suite 3 and EZCD creator installed,
    I tried with XP too.
    Could it be that I have a few installed?
    gaffer
  4. HMHB
    HMHB
    Nov 11, 2001
    25,510
    Nottinghamshire
    +3,850
    It should allow you to format the DVD with InCD, do you have the latest version of InCD installed ?
  5. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,349
    83
    +193
    You can also format the disk within Nero directly - Just look under the RECORDER option.
  6. the_gaffer
    the_gaffer
    OK, i'll have a look when I get home.
    If the disc is recognised in Nero, should it be able to record to it?
    gaffer
  7. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,349
    83
    +193
    Yes - but only once it's formatted (usually anyway!)
  8. simon100
    simon100
    Nov 2, 2004
    318
    +11
    I had a similar problem with my LG GSA-4160B. I tracked the problem down to Easy CD creator not recognising the drive. I removed Easy CD and just use Nero 5.xx now and all is well. My version of INCD does not recognise the LG either, so I have got rid of that and so far no affect on writing/copying disks, but I have yet to try and format a RAM disk, so might be hunting for a copy pf Nero 6 in the near future!
  9. the_gaffer
    the_gaffer
    Hi all,
    I got it working,
    I uninstalled EZCD.
    Lauched Nero, and in the drive selection, my burner was there twice, once for CDs and once for DVDs....I'd been selecting CDs!!!
    Anyway, it's working now,
    thanks again,
    gaffer
  10. HMHB
    HMHB
    Nov 11, 2001
    25,510
    Nottinghamshire
    +3,850
    I'm amazed that Nero installed with another package on there. When I last installed Nero it forced me to uninstall my other writing software first !
