DVD burner Firmware Update
Discussion in 'Blu-ray & DVD Players & Recorders' started by niccam, Apr 9, 2005.
  1. niccam
    niccam
    Apr 16, 2002
    239
    16
    N. IRELAND
    Hi could someplease put me right on some questions on updating the DVD burner Fireware
    1 is it really important to keep updated
    2 If I found a good source of DVD disc why would I need to update
    3 If I have to update is it easy to do
    4 If I update, will the DVD discs that I already have still burn and play
    Thank you for any help and info
  2. musukebba
    musukebba
    Jan 11, 2005
    689
    +16
    1. Might be...
    2. ...if you wanted to burn higher speed discs.
    3. Yes, especially the official manufacturer's updates.
    4. You might even find they burn at a higher speed.
    Do you have a particular firmware in mind?
  3. niccam
    niccam
    Apr 16, 2002
    239
    16
    N. IRELAND
    Thanks for replying but I have the PANASONIC 310 record speed is only 1x
    it is DVD-R/ DVD-RAM burner have not quite mastered the RAM BIT it yet so at the moment the speed issue does not concern me
    If I was to buy another PC burner DVD-R what would you suggest
    Any other advice . Thank you
  4. llanellijack
    llanellijack
    Mar 21, 2005
    291
    Llanelli
    +3
    Pioneer DVR-109 would be an excellent choice for 16x burning. SVP Communications are doing internal ones for £39.99 or external for £49.98. Cracking drives at a cracking price :smashin:
  5. niccam
    niccam
    Apr 16, 2002
    239
    16
    N. IRELAND
    Thanks for your help
