DVD Burner Compatability +/-
Discussion in 'Desktop & Laptop Computers Forum' started by WBC, Sep 22, 2003.
  1. WBC
    WBC
    Guys
    I'm gonna buy a dual spec DVD writer.
    What discs have better compatability with standalone DVD players???
    DVD -R ?????
    DVD +R ?????
    Stace :D
  2. gab2001uk
    gab2001uk
    Dec 3, 2002
    236
    +5
    The -R format is supposed to be more compatable but I have one DVD player that works well with +RW and +R, and SOME -R, and another that works with +RW and -R, but refuses +R completely.
    I use more -R as they are cheaper, especially the printable ones.
  3. nathan_silly
    nathan_silly
    DVD-R has the best compatibility with DVD-Video players. Use the best quality dye media you can get. I've tried Datawrite Yellowtop and Pioneer DVD-R's and they work on 1st generation DVD players. No problems whatsoever.
  4. Garrett
    Garrett
    Apr 21, 2001
    40,248
    2
    167
    The best thief you’ll never see.
    +6,670
    Think mine is a first generation DVD and my mate brought a Datawrite Yellowtop DVD+R round and it would not look at it. Burnt a slide show to a Datasafe One DVD DVD-RW but it would not look at that either but I believe re-writable can cause problems on old machines, (it did work on a Tosh 330 though).
  5. MikeyB
    MikeyB
    Sep 24, 2001
    80
    Swindon
    From my experiences DVD-R is the most compatible.
    As for which blanks to get, I've found that any made by Ritek are the bees knees, they work on every DVD player I've tried, and perfectly on the PS2.
    Look for ones with "ADVDINFO: .RITEKG..0x" (x being 2,3 or 4) on http://www.blankdiscshop.co.uk
