DVD Buring Problems
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by marshy.dave, Nov 4, 2004.
  1. marshy.dave
    marshy.dave
    I hope someone can help
    I am trying to transfer and burn my video footage from my camcorder. I have tried analogue footage and digitial footage but I keep getting the follow error message at about 25% of the burn process
    POWER CALIBRATION FAILURE
    This only happens if i try and burn more than 20 mins footage, upto 20 mins and it burns ok from either analogue or digital.
    I have tried using ULEAD Video Studio 8 and Pinnacle 9 but still get the same problems.
    Also any ideas why Pinnacle takes so damn long to render? its almost 10 times as slow as the ULEAD software.
    I am using Firewire to to the capture.
    Has anyone come across this?
  2. philipb
    philipb
    Mar 6, 2002
    2,087
    63
    Swindon
    +172
    Assume you're using a PC recorder? If so what model; how old? It may be a buffer under run issue. Have you tried burning at x1 speed?
    If the drive cannot handle the data being sent to it a firmware update might help. If its a bit long in the tooth then maybe a new one?
  3. marshy.dave
    marshy.dave
    Thanks Philip,
    I have also read that it maybe a media problem. I will try burning at a slower speed. Its Pioneer drive not sure what model.
  4. melliott1963
    melliott1963
    Nov 27, 2001
    427
    Ilford, Essex
    +4
    Just another piece of advice from my own experience.
    I wouldn't use Pinnacle to burn the DVD. Instead, select the option to create the image on hard disk and then use a dedicated program, such as Nero, to burn the DVD.
    I've found this to be a more reliable method.
