DVD Backup Jumps
Discussion in 'Movie Forum' started by hitched, Nov 2, 2003.
  1. hitched
    hitched
    Nov 2, 2003
    I have made backups of several DVDs I own. When I play them back on my Pioneer 656A the images start to jump as I get close to the end of the disc. If I play the disc on my DVD ROM in my PC there is no problem.
    I've backed them up using DVDXCOPY in DVD-R format using BULKPAQ discs.
    Has anyone else experienced this problem. I am keen to know if its a problem with the DVD player or something else I'm doing
    Dean
  2. nwgarratt
    nwgarratt
    May 5, 2002
    27,151
    +3,022
    That sounds like a media problem. I wouldn't use bulkpaq discs and don't burn at 4x speed.
    It is possible that some DVD players can handle it better.
  3. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    Avoid Bulkpaq at all cost.
    Use the cheaper (and much better) Arita or Zero Defex disks.
  4. Rob Pyatt
    Rob Pyatt
    I have a slightly differentproblem, also with the Bulkpaq discs. Sometimes the film just freezes for a second or so, then continues a snormal.
    I have tried burning at 2X, but it seems to be the same.
    I also suspect that it is a media problem of some description, so I read this thread with interest.
  5. nwgarratt
    nwgarratt
    May 5, 2002
    27,151
    +3,022
    What software are you using?
    DVD Shrink still leaves the layer pause in.
  6. betamac
    betamac
    If your looking for perfect playback always use If you have the money Verbatim disks they are not cheap but they are the best money can buy,
    If your looking for a cheaper disk which is still fantastic quality use Ritek Dye disks, lots of places selling Ritek G03 (2 X Speed) for less than 60p each at that price for Ritek you should never use anything else
  7. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    What? I've done tonnes of backups using DVDShrink and I've yet to see a layer pause on any of them.
    The layer pause only happens due to most standalone players not have a buffer so when the laser changes to the other layer you get a slight pause. Since 90% of all PC DVD drives use buffering they don't suffer from the layer change problem. So DVDShrink produces a perfect (layer change free) copy of the original.
  8. betamac
    betamac
    i 2nd That DVD Shrink Version 3 Beta 5 does not leave a layer change in the backup and after trying ALL programs on the market i can easily say DVD Shrink produces the best quality backup out of them all The ONLY way you will better it is if you spend 5 Hours Plus doing 5 Passes + on CCE.
    And the fact its free is amazing
  9. nwgarratt
    nwgarratt
    May 5, 2002
    27,151
    +3,022
    The final version of v3 will have layer change removal.
    I don't notice the layer change on my Cyberhome CH DVD 400 as it uses a DVD ROM drive. But, is it is noticeable on my Sony NS900.
    I have since, been removing the layer change manually using IfoEdit.
    I did a 5 pass with CCE and a Shrink version of Matrix Reloaded (with menu). There was very little in them. I decided to keep the CCE version, only as it took 10 hours and didn't want to waste it.
    I have been using £1.49 Memorex +RW discs as they are better than R and only a little bit more expensive. Plus, if I change my mind as can overwrite/re do them.
    I have also been using JVC DVD-R's and they work very well. They are only 99p as well.
  10. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
    Bulkpaq disks are plain dodgy - I actually have some -RW Bulkpaq disks with Ritek dye but even they are VERY ropey above about 4.2gig.
    I have also seen the freeze problem you talk about - this is probably a minor blemish on the disk, may even be a little bit of dirt that could be removed, give the disk a (careful) wipe and try it again - although it may have been the disk was "dirty" when burnt and the problem lies in the burn.
  11. betamac
    betamac
    Where did you get Bulpaq disks with Ritek dye as far as i am aware bulpaq dont use Ritek dye
    Also i USED to copy dvds and i burnt hundreds onto Ritek dye disks and NEVER HAD one bad disk either on burn or playback, as long as theres no dust before you burn you will have no problems
  12. Loafer316
    Loafer316
    Apr 8, 2003
    330
    agree with all the above...Ritek dye are supposed to be great however i did a backup of a film burnt at X4 and that got a bit jumpy in places..so i now i burn only at X2 speed. This was playing in a Pioneer 717...although the X4 burnt disc played fine in a friends sony dvd player.
    When re-encoding i've started using CCE with DVD2SVCD at 3 pass for long films (i.e harry potter) and the quality has been really good...havn't compared it with DVDshrink in deep analysis setting....so might try it out on a re-writable.
  13. nwgarratt
    nwgarratt
    May 5, 2002
    27,151
    +3,022
    Don't burn at 4x. Lots of people suffer from skipping problems. It does depend on the player though.
    CCE is great when compression of 30% to 40% is required. I use DVD2DVR and it only does the film.
    Shrink though is still excellent, expecially as it takes a lot less time (even with deep analysis). I combined LOTR FOTR EE onto one disc at 60% compression and it was stiill excellent on a 28% widescreen TV.
  14. pete18
    pete18
    Apr 14, 2002
    1,084
    41
    Torquay
    +3
    i have tried big pockets own brand dvd and they work fine
    from pete
  15. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    34,837
    Bristol
    +8,180
    Stick with Ritek media, I have burned loads of them at 4x and always perfect playback on my PS2, xbox and other dvd players, just avoid the overprints.
  16. pete18
    pete18
    Apr 14, 2002
    1,084
    41
    Torquay
    +3
  17. SagaLout
    SagaLout
    Jun 7, 2001
    343
    +17
    Yep, go with Ritek. Bulkpaq and many others generally use Princo dye which tends to be poor at the outer edges (anything above 3.9GB). They can also have longevity problems with a lot of people reporting discs appearing fine at first but unplayable 6 months later.
    Ritek G03 are great quality and very cheap at the moment.
  18. pete18
    pete18
    Apr 14, 2002
    1,084
    41
    Torquay
    +3
    so any of these will be ok to use
    Datasafe Ritek (1x/2x) DVD-R
    Branded Ritek Vision X2 DVD-R
    from pete
  19. nwgarratt
    nwgarratt
    May 5, 2002
    27,151
    +3,022
    Go for the Branded Ritek. They come directly from the Ritek factory.
    Traxdata is also branded Ritek.
  20. SagaLout
    SagaLout
    Jun 7, 2001
    343
    +17
    I use the datasafe ritek (white and silver on the top) and find them excellent. I burn quite a few off as I do wedding VHS to DVD conversions so its gota be reliable!
  21. nwgarratt
    nwgarratt
    May 5, 2002
    27,151
    +3,022
    I have quite a few datafsafe ritek fail while burning and even after a while after burning.
  22. betamac
    betamac
    I Would maybe start looking at the DVD writer or software you use? as i have burnt 100's of the datasafe ritek not one bad disk
    and on mediaforums loads of people use them, they are a superb disk for the money
  23. nwgarratt
    nwgarratt
    May 5, 2002
    27,151
    +3,022
    There is nothing wrong with the software (use lots of them) or the drive (used two different ones). It was the discs.
  24. betamac
    betamac
    ok, you must be a very unlucky person then :)
    I also have used loads of those FWS G03 which are sold out at SVP now and they are also a great disk
    I will stick to G03 until G04 reach 70p or less :)
  25. SagaLout
    SagaLout
    Jun 7, 2001
    343
    +17
    maybe a bad batch. I've burned around a hundred and havent had one failure. They burn right to the edge no problems. Was it a yellow disc by chance? I did get a batch of yellow ritek datawrites (same company as datasafe) which had a few problems (ugly discs too - dont look right for wedding dvds!)
  26. nwgarratt
    nwgarratt
    May 5, 2002
    27,151
    +3,022
    I did one discs a while ago, and watched it yesterday. Luckily the film is ok but one of the extras just freeze the disc. It was fine when I burned it and the last time I played the disc.
    I just stick with brand names now or ones in individual cases. I used JVC DVD-R's and they are the best so far.
    I do wonder if the spindle was to blame.
  27. betamac
    betamac
    To be fair i think every brand has and always will have batch problems, but the better the disk the less likely this is, EG the yellows i used to use were superb most of the time but you could easily get 4 or 5 bad batches in a row, with ritek i have yet to have a bad batch but no doubt there will be some around,
    If i was you i would order anouther batch of 10 or something, its just unfortunate you got a bad batch on your first buy, right now for under 70p there is no better disk
  28. PaulBoy
    PaulBoy
    Jul 14, 2000
    1,735
    Surrey UK
    +87
    Hi peeps ... sorry to but in but I have been thinking of getting a DVD Writer (to put camcorder stuff on but might burn the odd DVD copy as well - son at Uni keeps nicking mine!)
    What DVD drive / format would you recommend ? [I like Sony are their drives any good ?]
    Is a 80gb hard drive in my PC gonna be big enough ?
    Will a DVD writer write a CD ?
    Any recommended sites for an "idiots guide" ?
    TIA - Paul ;)
  29. betamac
    betamac
    The best drive with the least problems is the Pioneer 106 Multi Format Writer (Can Record CDs at 16X As Well) they can be picked up for £99 now, Theres very little difference between the formats, its all preference, i always use DVD-R myself as the G03 at 59p cannot be beaten on quality/price, most people tend to think DVD-R is slightly more compatible.
    80GB Should be fine, if you use something like Sony My DVD this will let you go directly from your Camcorder to DVD i have used it once and it works very well. If you are going onto PC in uncompressed format you might be struggling with 80GB depending on video length
    A good site is www.vcdhelp.com got some great guides
    The website for my DVD is http://www.sonic.com/
    Hope this helps :)
  30. PaulBoy
    PaulBoy
    Jul 14, 2000
    1,735
    Surrey UK
    +87
    MAC - Much obliged everything I needed to know ... Paul ;)
