Quantcast
DVD Audio to iPod
R
rnjones
Has anyone figured out how to extract the stereo tracks from a DVDV or DVDA to iTunes and hence an iPod?
Have a few DVDA's I would like to put on my iPod.
Rog
mistuk
Easiest way is to use a program like AudioHijack (I presume you're using a mac), which can intercept (for want of a better word) any audio that's being played on your mac and save it to a file. You can then import the audio into iTunes and sync with your iPod.
There are some command line tools available, but I've not had much success with them
Kev
R
rnjones
Hi Kev, I am not on a Mac but on Windows XP, but thanks for the info.
Rog
alexs2
Rog
You'll know that DVD-A is stored as encrypted data on the disc,and thus you'll be unable to extract the full 24/96 or 24/192 tracks from the disc....the best you may get is CD quality(i.e.16/44.1) from the digital out of your player/transport prior to transfer to the iPod.
DVD-V is a different matter,and there are programs which will do this,although the issue of copyright may arise.
