dvd audio to cd audio
Discussion in 'Computer Software & Operating Systems' started by curt, Dec 21, 2006.
  1. curt
    curt
    Hi folks
    I have alot of music dvds which I wish to play in my car . Is there any one piece of software which will take the audio off a dvd and covert it to play in a car stereo ( not mp3 ) . If not whats steps will I need to achive and what software can do these . What format do car stereos use ? is it WAV ? I have a cd burner with nero , not sure what version
    thanks
    Curt
  2. Jules
    Jules
    Oct 11, 2000
    5,651
    137
    +1,157
    Not an expert, but I think thise will work...
    1) You'll probably need to use 'DVD Shrink' or similar decrypting program. Most are free if you havn't got them already.
    2) Download 'VobEdit'... it's free! and use it to de-multiplex (demux) the .vob files. This will produce separate audio and video files.
    3) You should then be able to use a freebie audio converter (try 'switch') to convert the audio to .wav, then burn to CD.
    Or, simply feed the analogue audio ouput from your DVD player into the PC and capture real time to .wav.
    There may be quicker / better ways of doing this, but that's my suggestion.
  3. lazysod
    lazysod
    Jun 17, 2002
    489
    Leeds,Kent
    +15
  4. unique
    unique
    Aug 14, 2005
    9,381
    +1,211
