DVD-Audio problems
Discussion in 'Movie Forum' started by Kryters74, Jul 23, 2004.
  1. Kryters74
    Kryters74
    Jul 23, 2004
    244
    London
    +8
    I have just bought a Cambridge Audio Azure 540DVD and I thought I would try some audio DVD's which I purchased from play, the only trouble is when I put them in the player it just sits there and does nothing apart from the word title on the LCD display - any ideas?
  2. graham.myers
    graham.myers
    Mar 11, 2003
    6,230
    Leeds
    +931
    there will be a menu on the tv screen just like any other dvd
    if you press play it should start playing
  3. Kryters74
    Kryters74
    Jul 23, 2004
    244
    London
    +8
    I have tried that, it just sits with the cambridge audio logo on the screen (tv) and still does nothing.
    The manual states that DVD-audio will only work with the analogue 5.1 connectors, so I tried that (I normally use the coaxal connection for 5.1 and DTS), I had to make sure my amp was seeing that input which it was, but still nothing - no menus nothing!
    I have even tried pressing buttons at random, but apart from the open/close button nothing happens!
