DVD Audio problems with STR-VA555ES and Panasonic S75 DVD
Discussion in 'AV Receivers & Amplifiers' started by ollie501, Jul 17, 2003.
  1. ollie501
    ollie501
    Jul 14, 2003
    998
    Dorset, UK
    +25
    I have recently bought a Panasonic S75, mainly because of it's ability to handle DVD-Audio, as well as a decent range of DVD & VCD formats.
    The problem is, I cannot acheive an analogue multichannel signal for DVD-A.
    It plays Dolby Digital, DTS etc, through the optical connection with no problems, as well as stereo DVD-A.
    However,I am advised that to do multichannel, it needs to be done via analogue. No problem, I thought, and hitched it up to Multichannel 1 on my Sony Amp (STR-VA555ES). I have tried changing between PCM and Bitstream on the DVD, and nothing.
    The amp is fine as far as I can tell. I have an SACD player, which I have connected to each set of Multichannel connectors on the amp, to make sure they are both working, which they are. I have also tried the DVD player in each set of inputs, still with no effect. It won't play anything at all though the analogue connections, Dolby, or otherwise, and certainly not DVD-A, which is the main reason for buying this player.
    Does anyone have any advice, or experience of this. I have looked for a firmware update, although have so far been unsuccesful.
    Any advice very gratefully recieved. (
    Here's hoping!
    Ollie
  2. Johndm
    Johndm
    Jan 25, 2003
    1,809
    Bedford UK
    +56
    No probs with my 555 and Panny RA82..
    Sounds like a faulty player maybe?
  3. Family Guy
    Family Guy
    Go into the "speaker setting" menu on the DVD player and ensure you have "multichannel" enabled...there's only 2 choices, multichannel and stereo. Choosing multichannel will open up another menu to allow you to adjust the speaker levels through the DVD player...
