DVD-Audio and no Sub?
Discussion in 'Subwoofers' started by Timh, Apr 30, 2003.
  1. Timh
    Timh
    Sep 14, 2000
    5,175
    3
    3
    Altair-4
    +286
    I have a Toshiba sd-510 dvd-audio player connected via 6 phono leads to my Denon 1803 Receiver for advanced res playback, but I do not have a Subwoofer connected to my Amp.
    Will I be missing out on base, even though I have the amp set to no sub, (all base sent to mains).
    I have just tested my first dvd-audio disc, Fleetwood Mac's Say you will, and i found the base a little lacking :(
  2. Zig
    Zig
    Using the external 5.1 inputs the Denon will bypass all internal processing and send the DVD-A straight to the amplifiers. If you have no sub then yes you will be missing out on the .1 part of the mix. A good excuse for an upgrade?
  3. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    Is there an LFE channel on DVDA ?
  4. EvilMudge
    EvilMudge
    Sometimes, not always, and I think it depends on whether it is a remaster or a new album. There is bandwidth available and an encoding option present for 5.1 MLP.
  5. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,463
    United Kingdom
    +1,921
    The Toshiba 510 has no Bass Management for DVD Audio, even if you select Small speakers for the Centre and Surrounds it conveniently ignores that fact and sends full range signals to each channel. Unless your Centre & Surrounds can produce decent low end bass, you´ll be missing out.
  6. Timh
    Timh
    Sep 14, 2000
    5,175
    3
    3
    Altair-4
    +286
    Thanks all.
    The Fleetwood mac disc is 5.1 dvd-audio, so I guess i need a sub, well.... I do have one but its so crap i dare not connect it up :eek: :(
