DVD-A players .......all the same?
Discussion in 'Blu-ray & DVD Players & Recorders' started by sticker, Jan 7, 2005.
  1. sticker
    sticker
    Jan 14, 2003
    1,152
    36
    Sydney, Australia
    Has anyone out there done a back to back demo of DVD-A players playing DVD-A material?
    Regards
    John
  2. awhb
    awhb
    Hi John,
    Well I haven't for a long time. I can tell you that over analogue, the Denon 3800 wiped the floor with the Pioneer 757Ai in the DVD-Audio department but thats just one example under one configuration.
    Probably the most important question is whether you will be using digital (Firewire/Denon Link) or analogue, as in the former case it is the amp's DACs that you will be using whereas in the latter, it is the player's. Big difference.
    :cool:
    Adam
  3. Ovation
    Ovation
    Also, as I mentioned in the DSD-Universal player thread, not all players have flexible (or any) bass management/speaker distance settings (for DVD-A and/or SACD). Quite apart from all the differences other bits in the player might make (DACs, op amps, power supply, etc.), this is an important feature.
