DVD-A Output connections.
Discussion in 'Blu-ray & DVD Players & Recorders' started by UselessPratt, May 18, 2003.
  1. UselessPratt
    UselessPratt
    I think I read someplace that DVD-A requires a full 5.1 five phono connection to an AV AMP as well as the normal 2 stereo channels. Is that correct? ( I was just wondering whether I was required to spend half the price of the DVD-A player on MORE cables?? :eek: )
  2. nathan_silly
    nathan_silly
    Unless you have a Meridian DVD & Merdian Processor or other same make DVD/processor or AV amp combo.
    Not sure you need stereo out's, but defently need the 5.1 into your AV Amp.
  3. UselessPratt
    UselessPratt
    I suppose the stereo outs are for those who don't have an AV amp. So it's enough to just connect the 5.1. Thanks! :)
  4. graham.myers
    graham.myers
    Mar 11, 2003
    6,220
    Leeds
    +932
    my dvd player is only connected use optical for movies and 6ch in for dvd-a
  5. patmyhead
    patmyhead
    Feb 11, 2002
    588
    I o M
    Just had to say Mr uselessPrat I just love your name
  6. UselessPratt
    UselessPratt
  7. sounddog
    sounddog
    Dec 11, 2002
    3,370
    107
    Leicestershire, UK
    +461
    Yes you need the analogue connections ... but don't need to go OTT on cables ... 3 pairs of Cambridge Audio Atlantic @ £10 each will do for most systems.
    Vikki
  8. UselessPratt
    UselessPratt
    You know everyone seems to say something different, but the one time I actually found aome difference between cheap and expensive was on the cables between a CD and a pre-amp. I actually spent £150 for a pair of cables, I was so impressed. I was never entirely sure I knew why cd polayers seemed to most benefit. The question is, do dvd players benefit also, when used in SACD or DVD-A?? Cus, er, that would be nrealy £500 !!. Course, I would not spend that on MY dvd player, it's not that good. but even so, we are talking fairly big money!
