DVD-A on Denon3800
Discussion in 'AV Receivers & Amplifiers' started by petertully, Jul 13, 2003.
Tags:
  1. petertully
    petertully
    May 18, 2002
    27
    Leeds, England
    Real newbie question! I've just taken the plunge and gone for a DVD3800 setup, but haven't been able to get the DVD-A working through my Sony DB940 amp. I thought I'd just be able to hook it up through the 5.1 inputs, but it doesn't seem to work?!
    Can you play DVD-A through this sort of set up? Or do I need to go for a 6.1 amp setup?
    Any help much apprieicated.
  2. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,906
    71
    50 Rue St Georges, Paris.
    +32
    Sorry if this answers a question you didn't ask...
    You can play DVD-A discs through your Sony by optical 5.1 or co-axial 5.1, you need to select Dolby Digital 2.0 or 5.1 or whatever on your disc menu.
    Of course if you want to play hi-res audio from DVD-A, then you need to connect normal phono leads from the 3800 to 940, two for stereo or six for full multi-channel. Select multi-channel input on the Sony, select audio player mode in 3800 menu so the player will access hi-res disc layers, and select your choice from DVD-A disc menu.
    I have a 3800, if you need any specific answers I'll do my best. :)
  3. petertully
    petertully
    May 18, 2002
    27
    Leeds, England
    Many thanks! I'll give that a whirl and see how it goes.
