DVD A level settings
Discussion in 'Blu-ray & DVD Players & Recorders' started by rockyglw, Sep 3, 2004.
  1. rockyglw
    rockyglw
    Dec 15, 2002
    99
    +4
    I have a Pioneer 575a and a Marantz 4400 amp with a passive sub woofer and Kef Eggs. I have set the SW to off on the Pioneer so that bass is directed to the left and right fronts, which are connected to the passive SW. Please can anyone help with setting the speaker levels when using analogue 5.1 inputs. I have a SPL meter but this can only be used when setting digital inputs as the test tone is not available when using direct 5.1. Is there a DVD A or SACD test disk that provides a level setting tone.
    Hope thsi is not too confusing thanks
  2. Radiohead
    Radiohead
    Dec 24, 2001
    4,392
    Amazingstoke
    +432
    Your first problem is that the 575 doesn't offer bass management for analogue outputs.
    Without that you're a bit stuffed...
  3. rockyglw
    rockyglw
    Dec 15, 2002
    99
    +4
    No but the Marantz does allow a certain amount of bass management. Bass is not really the problem as far as I am concerned, I am actually more interested in getting the levels from each speaker the same anyone know how I can do this please?
