DVD-A connections
Discussion in 'Blu-ray & DVD Players & Recorders' started by Alio, Dec 20, 2002.
  1. Alio
    Alio
    If I upgrade to a DVD-A compatible player, e.g. Pioneer 656a will my Marantz 4200 decode the dvd-a using the digital input or do I need to look at upgrading the amp as well.
  2. alpha10
    alpha10
    Jan 22, 2002
    3,197
    Essex
    +191
    You need a 6 channel analogue input on your amp ( I don't know if your Marantz does?) for surround sound or just an ordinary 2 channel input will do if you want to listen only on hi-res stereo..
  3. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
    looking at the spec on the website the 4200 doesn't have a multichannel input (6 channel input) so you are limited to only two channel DVD-A...check your manual though as the tech specs maybe wrong on the site...
    JJ
  4. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
    p.s. the dvd player will decode the DVD-Audio and merely pass the 6 channel input to the amp for amplification. Most DVD-A players output DVD-A via analogue connections only at the mo (hence the 6 channel input)
    Players are staring to appear which can pass DVD-A across \ digital link, but then you need an amp that can accept DVD-A via a digital...this feature is only available on high end amps from denon and pioneer at the mo and there are still copyright issues I believe...
    JJ
  5. Alio
    Alio
    Thanks for the info
