DVD-A and SACD outputs from players
Discussion in 'Blu-ray & DVD Players & Recorders' started by floatingkiwi, May 10, 2004.
  1. floatingkiwi
    floatingkiwi
    Sep 8, 2003
    134
    Taupo, NZ
    +5
    Hi all
    Just wondering how a player like the Arcam DV-89 (that plays DVD-A) outputs the signal? (refering to the abscence of an onboard decoder)
    Now, as far as I know the whole idea of copy protection means that the digital output isn't going to work with a DVD-A right? Or does it down-sample?
    Can anyone clarify how a player with no onboard decoder outputs signals from DVD-A's and SACD's?
    Thanks a million.
  2. Philly112
    Philly112
    Oct 17, 2003
    4,439
    Frodsham
    +1,845
    AFAIK, it just outputs through the 5.1 analogue sockets, same as stereo if you don't use the digital connection.
    I presume there is some sort of bass management in the player, as you probably won't be able to use any digital management in the amp.
    There are quite a few players about now that output DVDA and SACD digitally (mainly the top end Denon and Pioneer Universal players), but I don't think Arcam have such a player.
  3. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    It does have an onboard decoder & ouputs DVD-A thru the six analogue outs. Also has onboard bass management.
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,533
    Rainham Essex
    +2,517
    As stated by vonhosen, the Arcam DVD players do have an onboard DVD-A decoder, but none of them can play SACD's.
    DVD-A & SACD can not be transfered via the standard digital coax or optical cables, but some of the Pioneer players & receivers have iLink that can transfer the formats. The new version of Denon Link does also work with these formats.
    DVD-A disks also contain either a Dolby Digital or DTS multichannel mix that can be played on any DVD player and can be connected by the standard optical or coax cables.
    Mark.
  5. floatingkiwi
    floatingkiwi
    Sep 8, 2003
    134
    Taupo, NZ
    +5
    Thank you folks. I suspected as much, (and am actually kicking myself for not checking the DV-89 on the arcam site again!)
    One would then propose that for a DVD-A or sacd player to output properly it "MUST" have an onboard decoder?? (or otherwise be downsampled and mixed via the conventional stero outputs)
