DVD-A and my amp (silly question)
Discussion in 'AV Receivers & Amplifiers' started by stevegreen, Jul 12, 2004.
  1. stevegreen
    stevegreen
    May 14, 2001
    8,745
    in my Hymer
    +921
    I have a Pioneer DV565-a and a Yamaha RX-V496 RDS and a DVD-A disc.
    My amp has connections at the back marked 6 channel external decoder. If I connect the outputs from the DVD player to these will the DVD player decode the DVD-A and then send the signal to the amp in its correct format so that i get the full benefit of the 6 channels?
    I tried to find my instruction manual but it's in the loft and i have not got any ladders :lease:
  2. Zone
    Zone
    Jun 24, 2001
    6,775
    Barnsley
    +2,507
    Steve, in answer to your question, yes.
    PS, I can lend you a ladder if needed alternatively have a look here for an online manual :)
  3. roversd1
    roversd1
    Yes... it is a silly question. :devil:
  4. stevegreen
    stevegreen
    May 14, 2001
    8,745
    in my Hymer
    +921
    Great, I now need to get some ladders so I can get up the loft to find some spare phono leads. I think they are in the same box as the manual :rolleyes: :D
