DVD 4 speed -RW discs
Discussion in 'Blu-ray & DVD Players & Recorders' started by tvman, Jan 22, 2005.
  1. tvman
    tvman
    Mar 15, 2004
    4
    london
    Hi, does anybody know the best place to buy these discs?.Most places i've tried only have 2 speed.
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,212
    Argyll
    +2,267
  3. JethroUK
    JethroUK
    Dec 5, 2004
    1,141
    i dont get that - i've never had any trouble with any DVDR's i've put in mine (whatever was the cheapest at the time) - but i've always assumed:
    disc write speed (x4, x8, whatever) is the 'guaranteed', 'maximum' (upto)speed you can write on it
    higher-write-speed discs = higher grade film = more receptive = backward compatable with any lower speed writers
    i.e you could put a x million disc in x 1 writer - but if you put x 1 disc in a x 2 writer you can expect trouble, because the disc is not guaranteed to be receptive at that speed
    saying that, i've written @ x12+ to x4 discs, and although i fully expected to chuck half of them away, they worked OK
    is that not so? - or more specifically, has anyone, ever had a problem using high-speed disc in a low speed writer? (that's the bit i dont get - and that's when i'd definately send the discs back)
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,212
    Argyll
    +2,267
    JethroUK, I assume you are using DVD+ media though? DVD-RW has compatibility problems between v1.1 and v1.2 media types. One of the reasons why DVD+RW is more popular than it's minus competitor for PC use. DVD-RAM and DVD+RW do not have problems yet - although they will have at faster speeds.
  5. captainpacific
    captainpacific
    Jan 9, 2005
    261
    Hampshire
    +51
    I'm with Rasczak on this one. It's worth checking your manual about the disc versions to use. Each machine will vary and, for the sake of a quick check, why not buy the sort that are guaranteed to work well? Also, some machines will use a wider variety of media that they state in the manual but then you find that some of the functionality is lost when not using the "stated" media types.
    SVP are a great supplier and Verbatim MCC code DVD-RW 4x discs are a very good quality choice.
  6. PhilipL
    PhilipL
    Jan 18, 2002
    3,787
    103
    +421
    It does, the new 8 speed version media will not record in any existing hardware.
    As for DVD-RAM, Raszcak will say (no guarantee) that all faster DVD-RAM media will be backwards compatible, but then so did the +RW Alliance before 8 speed +RW came about, only to break that promise later, so there are no guarantees. The same issues will be apparant on Blu-Ray and HD-DVD as re-writable speeds increase.
    The facts: Phase change material used on DVD-RW/+RW, DVD-RAM, and CD-RW, can not be made to cover a broad range of writing speeds in the way write-once dyes can hence the breaks in writing compatibility for faster media. Its the way the technology works.
    Regards
    Philip
  7. Rasczak
    Rasczak
    Apr 3, 2002
    21,212
    Argyll
    +2,267
    This isn't a DVD-RW v DVD+RW v DVD-RAM argument Philip so you can climb down from actions stations for defence of -RW!
    And 8x +RW media isn't available yet - thus in the future is quite a good description of when the problem will occur. And notice I did use the word "will" in my post!
    I said so far DVD-RAM doesn't have a backwards compatibility issue - indeed AFAIK the proposed specs for 16x DVD-RAM will be incompatible - but then nobody is seriously considering 16x DVD-RAM because there is no market for such discs. By the time they arrive they will be completely over-shadowed by HD-DVD/BluRay - so nobody will really care.
    But as things stand now there is an issue with compatibility of 4x DVD-RW media which needs to be mentioned. If/when/as it becomes an issue for other formats then that too will be mentioned!
  8. PhilipL
    PhilipL
    Jan 18, 2002
    3,787
    103
    +421
    The specs are finalised and it has already been made known that 8 speed +RW media will not be backwards compatible for recording. You just said in the future, I offered a more complete picture of that future that you left out.
    Then please do not turn it into one then.
    Regards
    Philip
  9. kitschcamp
    kitschcamp
    Sep 13, 2004
    216
    28
    Australia
    +42
