Dvd 32r problem
johnson
Established Member
Joined
May 12, 2001
Messages
552
Reaction score
Points
98
Location
Essex
I've had my Dvd32r powered down for 2 weeks while my av192 has been away.
I've powered it back up today and I cannot get a component signal to my plasma.
The strange thing is, the front panel of the dvd says composite.I've never seen this before.
Obviously I've checked in the menu that it's on component, but no picture.
The display says PSM and composite when it starts up.
After that, just composite!
I've connected my non psm dvd32r and have a picture just fine on the plasma.
Any ideas?
Regards
you have 2 :clap: DVD 32r's, you bas steward I haven't got any!! :devil:
Try typing "RGB" at the numbers on the remote, it helps me when I got OSM output poblems. The loader has to be empty.
Showing composite on the display means the PSM has been set to the external composite input rather than the internal link from the DVD32, need to reselect the internal link (can't remeber how as I type this but I'm sure it is in the manual :))
Thanks John, I'll have a look.
Not sure why it decided to do this!!
Regards
Thanks for the input Remi.
Its something like shift + 1,2 or 3 to switch PSM inputs. I had a weird change when the remote batteries were low once......
Thanks for the help guys.
Interestingly, the player cured itself after about an hour?!!?
I have been working since, so couldn't reply.
Regards
Sony BRAVIA 9 Mini LED TV: The Best HDR TV EVER?
Back
