DVD 32 FLR??help
Discussion in 'TAG McLaren Audio Owners' Forum' started by baloonet, Sep 2, 2004.
  1. baloonet
    baloonet
    Can somebody help me?
    If I buy a TAG dvd32 flr in the USA, how can I delete region 1 to set multiregion or region 2???
    Is there a problem with the voltage??
    I'm from Belgium and would be sure it's possible to do this.
    Thank you very much.
  2. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Ask the helpdesk, it isn't really wise to post the method here but it is very simple to alter the region code.....As for voltage differences well the uSA is 110v and Belgium 220V, best ask the helpdesk before plugging it in mate!
  3. mlinhares
    mlinhares
    Jul 1, 2001
    354
    Portugal
    Codefree sequence:
    1. no disk in the player
    2. close the tray if it's open
    3. key in 734* (where *is the region)
    For memorization purposes remember 734 is REG(ion).
    0 is for all regions.
  4. ThomasBelgium
    ThomasBelgium
    Hi Baloonet,
    You've got PM!
    Or in Dutch: Ik heb je 'n privéboodschap gestuurd...
    ThomasBelgium
