DVB PCI card advice needed...
Discussion in 'General TV Discussions Forum' started by Clint C, Oct 2, 2004.
  1. Clint C
    Clint C
    Dec 10, 2002
    425
    Wiltshire UK
    +4
    Does anyone know if this card's other internal connection is a passthrough connection? It doesn't mention it anywhere I've looked but it begs the question "What is it for?".
    I have the need to pass the sat signal through the card and out to my sky box so if anyone knows a CI card that will do the job I'd greatly appreciate it.
    Thanks in advance.
    Clint.
  2. Abstrakt
    Abstrakt
    Dec 12, 2003
    247
    28
    +40
    Hi Clint,
    Have you considered getting a smart priority switch, instead of limiting your choices to DVB cards with LNB passthroughs? You’d simply connect your LNB to the switch’s input, your DVB card to the priority output and your receiver to the secondary output.
    Here’s the switch I use:
    http://www.globalcom.co.uk/accesories/sps1.html
    Cheers.
  3. Clint C
    Clint C
    Dec 10, 2002
    425
    Wiltshire UK
    +4
    Superb, cheers matey. :thumbsup:
  4. Clint C
    Clint C
    Dec 10, 2002
    425
    Wiltshire UK
    +4
    Abstrakt, no I hadn't considered it but it's now on my list of things to buy.
    Has anyone tried out or has any knowledge of the Twinhan VisionDTV VP-1030A?
    Clint.
  5. Clint C
    Clint C
    Dec 10, 2002
    425
    Wiltshire UK
    +4
    Thanks Abstrakt, I ended up getting the SPS1 from ebay for 99 pence, with postage @ £2.50 :D and it works a treat.
    I received my Skystar 1 CI yesterday and installed it into my pc. I have a motorised dish set up and almost screwed my regular Sky reception up by "tinkering" with the Skystar software for setting up the dish, LNB, etc. I eventually retrieved the situation. Had my first look at Euro1080 and AstraHD although just on my 15" TFT monitor (for now) and can't wait to fire it up tonight on the pj. What suprised me was that my Athlon XP2100+ processor was up to the job with 74% average CPU activity, excellent. :clap: :clap: :clap:.
    Clint.
  6. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,264
    Manchester
    +756
    To answer the original question, yes it has LNB loopthrough.
    I use the original Twinhan VBP1020 looped through to a Broadlogic BL2030 card here.
    It's possible to watch a programme on the BL card whilst simultaneously examining the same transport stream with
    TSReader via my TH card.
    Chris Muriel, Manchester.
