DV89 to Region 1
Discussion in 'Arcam Owners' Forum' started by Northmoorblue, Aug 1, 2004.
Tags:
  1. Northmoorblue
    Northmoorblue
    May 18, 2004
    49
    Just bought the Arcam DV89 DVD player and believe it will only play region 2 out of the box. I have several region 1 dvd's and need help.
    Is there an easy way of converting it so it will play region 1 discs. I've heard that there are codes you can use on the remote? Is this true? If so what are they?
    Thanks in advance for anyone that can help me
    Northmoorblue
  2. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,221
    83
    Over the Hill & Far Away
    +139
    open draw type 111113 and then close draw.
    turn machine off/on and it should then me multi region full stop etc etc
  3. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    Also (another method):
    Bring the player into the Setup Menu and type 4792. This will display a hidden Service menu that has an item for selecting region (None, 1..6, Auto).
    Dean
  4. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,221
    83
    +139
    I was under the impression that the hidden menu method did not work quite in the way expected... though tbh I never really tried as once on region 13 I have not thought about it again in the last 3 years :)
    Matt
  5. Northmoorblue
    Northmoorblue
    May 18, 2004
    49
    Thanks Matt, dwette
    Will try your suggestion first Matt
    Northmoorblue
  6. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,570
    Edinburgh
    +1,268
    The correct code for the DV89 is as follows:
    1. Press 'Setup' on remote
    2. Pres '4792' on remote
    3. You are now in engineer's menu
    4. In the region setting select 'Auto'
    5. Press 'Setup' on remote
    6. Switch off player for 5 or more seconds
    7. Switch on player
    8. Player is now multi-region
  7. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,570
    Edinburgh
    +1,268
    For anyone who needs to know the above method applies to the Arcam DV88+, DV89 and DV78 only. For the DV88 and DV79 use the following method:
    1. Open disc drawer
    2. Press '1111' on remote
    3. Press '13' on remote
    4. Switch off player
    5. Switch on player
    6. Player is now multi-region
  8. malcolm mccabe
    malcolm mccabe
    Does this also work on the DVD88 Plus ?
  9. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,221
    83
    +139
    Yes I have a DV88 + and always used the method descriped by CrustyLoafer. I think using the 4792 menu would also mess around with the default video settings.. cannot remember...Basically I have set it once 3 years ago and never needed to worry since.
    Matt
  10. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,570
    Edinburgh
    +1,268
    As you can see above I have already told you that it does. DV88+ is a DV88 plus.
  11. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,221
    83
    +139
    I did not even notice that :)
