DV89 and AVR300 possible problem
Discussion in 'AV Receivers & Amplifiers' started by galewis1, Oct 1, 2004.
Tags:
  1. galewis1
    galewis1
    Apr 11, 2004
    354
    Peterborough
    +4
    Don't know if this is a problem or not.... When I'm looking at the Arcam splash screen (i.e. when no disc is in the drawer), I notice that after a little while the logo starts to move around (presumably to avoid screen burn on TV's and plasmas). Problem is that the logo seems to be off centre in that it drifts off the far right edge of the screen, but doesn't go all the way to the left of the screen.
    When I check a test signal using DVE, everything looks good however, which makes me think my display is OK (Infocus 4805 DLP Projector). Am I experiencing an image shift between the DV89 and the AVR300 perhaps? I am using the receiver for DVD video switching via component. Doesn't make any difference if I output progressive or interlaced from the DV89.
    If anyone else has a DV89 and AVR300, i'd appreciate if they could check.
    Gary
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    I used to have a DV89 and vaguely recall that when the logo started moving around it did the same. I wouldn't worry about it, as long as your getting a centred image when your watching DVDs that's all that matters.
  3. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    If you have the Avia disk (or something similar) display the overscan test pattern. That will tell you how well the image is centered. I wouldn't get concerned about the Arcam slash screen at all.
  4. gilesm
    gilesm
    Aug 29, 2002
    179
    UK
    Gary, Yep mine does exactly the same, don't think it's a problem though
