DV88 - worth upgrading to progressive?
Discussion in 'Arcam Owners' Forum' started by sooperscoop, Sep 13, 2005.
  1. sooperscoop
    sooperscoop
    So I'm taking a long hard look at my trusty old DV88. I've had it about 4 years but never upgraded to progressive because I was in the US at the time and the dealers seemed a bit clueless.
    So, has anyone done this (I know it's a factory upgrade) and how much would it cost?
    It is really worth it? I'm sure DVD players have moved on and maybe a DVD88 with prog. scan would get it's arse kicked by a new £200 player?
    Any thoughts?
  2. steeled
    steeled
    Apr 23, 2002
    484
    28
    Maidenhead
    +53
    I don't think the upgrade is available any more. Arcam no longer make players using the chipset that is in the DV89.
    If you want to upgrade consider the DV78 and DV79 depending if you require DVD-A.
    HTH
  3. sooperscoop
    sooperscoop
    Yeah, I guess you could be right, it was a long time ago, tho the website still mentions it.
    Might be time to part with some cash....
    Thanks.
  4. per-Sony-fied
    per-Sony-fied
    Jul 24, 2005
    2,277
    +100
    I talked to Arcam some months ago, about May time and they certainly offered the upgrade then. From what I remember they just stick a new chassis board in it. technically making it a 89 without DVD-A so will have the 89 Zoran vadis chip implanted which differs from the 88 you have. The price for upgrade is not cheap about a couple of hundred quid. For this money you might as well sell the 88 for what you can get and buy a 2nd hand 89 (fully DVD-A spec'd). The pic quality is still extremely good and I doubt any new player of a few hundred quid would challenge it.
  5. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    The progressive scan upgrade adds the Silicon Image 504 deinterlacer, which is superior to the Vaddis 5 now used for deinterlacing in the newer Arcam players. It will bring the player up to DV27A video quality, and is well worth it in my opinion. I added this upgrade to my DV88Plus last summer and it was a big improvement over using the Vaddis 5 it used for progressive scan before the upgrade.
    DVD-A is a seperate upgrade.
  6. Warpaint
    Warpaint
    Jul 26, 2003
    589
    28
    Edinburgh
    +61
    I agree with Dwette.
    The DVD88 with Silicon Image prog scan upgrade board is better than any of the current Diva range.
  7. X6TUS
    X6TUS
    Mar 16, 2005
    145
    19
    I'd be interested to know if you get a price for the upgrade as I am in the same situation too. Buy a DV79 for £999, or a progressive scan upgrade for less than £999 :)
  8. per-Sony-fied
    per-Sony-fied
    Jul 24, 2005
    2,277
    +100
    You could of course buy an ex dem DV89 which essentially only lacks the HDMI socket. I bet it performs as well in every other respect.
  9. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    Good point, because the DV89 has the Silicon Image SiI504 deinterlacer.
  10. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,525
    Edinburgh
    +1,243
    The DV89 did not have the Sil504 fitted as standard, it used the Zoran Vaddis 5 chipset for deinterlacing. The Sil504 board was an optional upgrade which allowed simultaneous output of deinterlaced and interlaced pictures.
    You can check this on the information page on Arcam's website below:
    http://www.arcam.co.uk/archive/diva/cinema/dv89.html#DesignDetails
  11. LFC4ever
    LFC4ever
    Mar 18, 2004
    428
    Henley on Thames
    +3
    I'm a bit confused - I have a dv88 plus which I thought was the same as the dv89 but without dvd audio?
    So what upgrades could be applied to the DV88 plus?
  12. per-Sony-fied
    per-Sony-fied
    Jul 24, 2005
    2,277
    +100
    All the same I bet for most people with 'normal' viewing experience, those with standard size TV's whether CRT or LCD would not notice any major difference, certainly not to the cost of modification.
  13. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    Doh! That's right. What was I thinking?
    Thanks for pointing out the correct info Crusty.
  14. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,525
    Edinburgh
    +1,243
    You can still get the Sil504 board fitted which will give a higher performance progressive output.
  15. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,117
    83
    Over the Hill & Far Away
    +119
    Or you can have the DVD Audio board added :)
    My DV88 was updated to + spec many moons ago.. never bothered with DVD-A as it was about £350 just to get that.. my player is 5 years old in Jan !
    Matt
  16. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    I never got the DVD-A upgrade. Just didn't see the point for such an expense when there are 2 competing and incompatable standards for hi-res audio. I expect the 2 will just kill each othe off in the long run. Ditto for the emerging high def video DVD standards. There's a disaster we get to witness in the coming years.
  17. tpm45
    tpm45
    Sep 14, 2005
    88
    11
    I have a Pioneer 565 or is it 656 ?? anyway its connected to the first Philips tv incorporating pixel plus tech. The picture and sound are outstanding. Would buying an Arcam Diva dvd really improve the sound and vision all that much. anyone.
  18. per-Sony-fied
    per-Sony-fied
    Jul 24, 2005
    2,277
    +100
    Err without actually knowing the quality's of the Pioneer I can't say for sure but I can say it beats a Sony DVP-S7700 for picture and sound which is already very good in this respect. After watching the Arcam for some time it has become clear that the Sony lacks a fruity colour palette, looks more 2 dimensional and edgy.
    The Arcam sound is altogether more free with better kick and impact, greater resolution in the bass, but you could say the Sony has more of it!
    The worst aspect of the Arcam for me is the time it takes to read discs and move on to the next title. The Sony is absolutely superb in this respect and has a much quieter and smoother DVD loading tray.
  19. Ikki
    Ikki
    Feb 23, 2004
    1,173
    2
    67
    Lancs
    +97
    The DV88 Plus (Vaddis 5) is quite an improvement over the Pio DV444 which wasn't bad in itself and probably similar to your players as they tended to use similar chip sets in the low to mid range players. The sound quality is much better. :smashin:
