DV88 remote query
Discussion in 'Arcam Owners' Forum' started by robfitzp, May 31, 2004.
Tags:
  1. robfitzp
    robfitzp
    Dec 12, 2002
    1,190
    38
    Bristol
    +20
    Do Arcam use unusual remote codes? I am trying to program the remote from a Pioneer AX10 to control a DV88+ and am not having much success - this is the first remote it has had problems with.
    Anyone tried something similar?
    Rob
  2. bedders
    bedders
    Apr 29, 2003
    224
    UK
    Can't say specifically, but the manual for my Arcam CR-80 remote (that comes with my AVR300) shows Arcam DVD players using code "0732" - hope this helps.
    You can also look at http://www.remotecentral.com which is a site dedicated to remote controls, especially the learning type.
    Regards,
    N
  3. mjn
    mjn
    May 24, 2001
    22,093
    Herts, England
    +9,848
    in the setup of the player, specify the remote as "other"
  4. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    The DV88+ uses RC5 type IR codes. I've programmed a Home Theater Master MX-700 using a tool to generate the learned IR codes, and it works just fine.
    Sometimes when learning codes to another remote you may have to vary the distance between remotes and how long you hold the button down. I've also had issues in the past when trying to learn codes with halogen lighting overhead.
    Dean
  5. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    I think that's just a reference to the CR-80 internal database for devices. The RC5 system code for Arcam DVD players is 25. For example, the discrete power on code is 25-123 and power off (standby) is 25-124. The AVR200/300/AV8 system code is 16.
  6. Kazuya Mishima
    Kazuya Mishima
    Dec 11, 2002
    1,418
    North East Scotland
    +65
    What he said.
  7. robfitzp
    robfitzp
    Dec 12, 2002
    1,190
    38
    Bristol
    +20
    Thanks all, will try the 'other' setting.
    Rob
  8. robfitzp
    robfitzp
    Dec 12, 2002
    1,190
    38
    Bristol
    +20
    Tried the other setting - no joy.
    The problem I have is that I cannot get the AX10 remote to learn from the Arcam remote. As it works with all of the other remotes I have tried (primare, MF, meridian, lights etc) I wondered if there is something peculiar to arcam remote codes?
    Anyone have any ideas?
    Rob
  9. mjn
    mjn
    May 24, 2001
    22,093
    Herts, England
    +9,848
    Can you enter the hex codes directly into the AX10 remote?
    If so, i can send you the hex codes via PM.
  10. robfitzp
    robfitzp
    Dec 12, 2002
    1,190
    38
    Bristol
    +20
    That is another question....I'll have a look in the manual!!
    Rob
