dv88+ problem
Discussion in 'Arcam Owners' Forum' started by robfitzp, Apr 10, 2005.
Tags:
  1. robfitzp
    robfitzp
    Dec 12, 2002
    1,190
    38
    Bristol
    +20
    I have just sold my DV88+ to a chap in the US who is having a problem with S video output. His email to me said 'It plays cd's okay but the video output through s-video rolls and rolls. DVD sound is okay too, just the screen'
    I have suggested trying a different output - not much point buying one of these if you are not going to use component or RGB - and also checking that TV system is set to NTSC or Auto rather than PAL.
    Any ideas?
    Rob
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    It is almost certainly because the player is set to output PAL signals. In the States there is no real requirement for their displays to be compatible with video formats other than NTSC so they don't bother. Tell him to plug it into a display that will accept PAL signals, change the output on the player to NTSC then plug the machine back into his normal display.
  3. robfitzp
    robfitzp
    Dec 12, 2002
    1,190
    38
    Bristol
    +20
    Crustyloafer
    Thanks for the reply - pretty much what I told him to do.
    Would the OSD be visible even if the player was set to PAL?
    Rob
  4. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    Yes, but only if you feed the picture into a display that will accept a PAL picture.
  5. robfitzp
    robfitzp
    Dec 12, 2002
    1,190
    38
    Bristol
    +20
    Right, I think the OSD is visible as he has been able to turn the prog scan output off. He also says the player is set to NTSC, but the screen still rolls vertically. Does it on S vid and on composite, don't think he has tried component.
    Player worked fine before it was sent, any ideas?
    Rob
  6. mjn
    mjn
    May 24, 2001
    22,235
    Herts, England
    +10,072
    Deffo sounds like a 50hz / 60hz issue, which his TV would have to support.
  7. robfitzp
    robfitzp
    Dec 12, 2002
    1,190
    38
    Bristol
    +20
    MJN
    Can you elaborate a bit - I would have thought that if he set the player to NTSC it would output 60hz hence there should not be any problem?
    Am I missing something here?
    Rob
  8. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    Has he tried plugging the DVD player into any other type of display?
  9. robfitzp
    robfitzp
    Dec 12, 2002
    1,190
    38
    Bristol
    +20
    Not yet - I have asked him to and also to try component.
    Rob
  10. robfitzp
    robfitzp
    Dec 12, 2002
    1,190
    38
    Bristol
    +20
    All sorted - he tried it on another TV and it worked.
    Thanks for your help everyone!
    Rob
