DV88 Paperweight
Discussion in 'Blu-ray & DVD Players & Recorders' started by Kell, Dec 13, 2002.
  1. Kell
    Kell
    Ok, a little bit of help required guys. My DV88 is now a paperweight after a rather poorly timed power outage whilst upgrading the firmware. It's with my local dealer (make that the only dealer in Ireland) who've had it for 2 weeks now with no word on repair. According to the Envytech website the flash ROM's just need to be replaced and all should be ok. Can someone confirm this and put me out of my misery.
    If it is just a case of the flash ROM's needing replacement any ideas how much I'm looking at £££-wise?
    Cheers!
  2. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,688
    UK
    +116
    if you have a good Arcam dealer, ask them if they can say that it happnened to them whilst doing the upgrade FOR you....they may be more sympatheric to the dealer than an end-user doing the upgrade (as this is what they reocmmned)
    PM "John Dawson" who should be able to give you a ballpark figure for this work...
    JJ
