DV88+ PAL Progressive
Discussion in 'Arcam Owners' Forum' started by Wilbur, Jul 7, 2004.
Tags:
  1. Wilbur
    Wilbur
    May 16, 2002
    309
    16
    London
    I took home my brand new DV88+ last night looking forward to seeing the reults of PAL Progressive output on my panny plasma but ended up slightly confused.
    The manual states that the machine only outputs a progressive signal from an NTSC disc or when the display is set to NTSC (which it then goes on to say would cause flicker from a PAL disc)...
    Please could somebodyb explain? Does it really output PAL progressive? how to I set it up to do so? And why doesn't the manual shout about it?!
  2. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,132
    83
    Over the Hill & Far Away
    +119
    I have mine set to auto for the output (NTSC for NTSC discs/PAL for PAL).. and in the menu there is a progressive option which you can have ntsc only or NTSC and PAL (525/576) prog scan.. and thats it.
    Works like a charm
    Matt
  3. Wilbur
    Wilbur
    May 16, 2002
    309
    16
    London
    Thanks Matt,
    I'll get it hooked up and set as you suggest this evening.
    Do you agree that the manual gives the impression the machine doesn't do PAL progressive or is it just me?
  4. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    When we wrote the manual (and printed thousands of copies) PAL PS wasn't legal. So it wasn't referred do directly. In practice it is fully supported in the DV88Plus.
    HTH.
    John Dawson (Arcam)
  5. Wilbur
    Wilbur
    May 16, 2002
    309
    16
    London
    Excellent - thank you!
  6. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,132
    83
    +119
    Mine was a DV88 to start with and I can honestly say have never looked at the manual ;)
