dv88+ - connect via amp or direct to plasma?
Discussion in 'Arcam Owners' Forum' started by loz1, May 16, 2004.
Tags:
  1. loz1
    loz1
    Dec 11, 2002
    84
    Edinburgh
    Hi there,
    Just bought a DV88+ and was wondering whether I would notice any difference in PQ if I was to connect it via my Denon 3803 instead of directly to my Pioneer 433 MXE. I currently have an HS2 and Nokia 211 connected via a JS RGB to Component box to the Denon and then via component to the plasma. This means it's easier and cheaper for me to connect via the 3803 as I'm already using the component input on the plasma but thought I'd ask as I want to get the most out of what I hear is a great player.
    Cheers,
    Lawrence
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,437
    Rainham Essex
    +2,470
    The theory is that the extra connections involved in going via a receiver will result in a loss of PQ. In practise several people on these have reported that they can see no loss, so with that in mind and the fact that it will save money and make your life easier I would suggest you connect via the receiver.
    Mark.
  3. loz1
    loz1
    Dec 11, 2002
    84
    Edinburgh
    Thanks Mark. I've taken your advice and ordered myself a component lead from the forum.
    Cheers,
    Lawrence
