DV88 bi-amping question
Discussion in 'Blu-ray & DVD Players & Recorders' started by Devil On Your S, Oct 23, 2005.
Tags:
  1. Devil On Your S
    Devil On Your S
    May 24, 2004
    1,654
    Lincoln
    +171
    Just a quickee, would it be possible (or indeed worthwhile) to use 2 integrated amplifiers to bi-amp off a DV88? The DV88 has 2 analogue outs, and my current amp is a Marantz PM7200, which has no pre-outs.
  2. steeled
    steeled
    Apr 23, 2002
    499
    28
    Maidenhead
    +54
    I don't think this would work to well as you would have to be careful to keep the volume on the two amps set to the same level. If you did not do this you would find the tone would not be correct.
    HTH
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,578
    Edinburgh
    +1,269
    Bad idea, get a matching power amp to the integrated amp you plan to keep and get rid of the other one.
