dv88+audio delay how to turn on
Discussion in 'Blu-ray & DVD Players & Recorders' started by jmack, Jul 30, 2003.
  1. jmack
    jmack
    hi how do i turn the audio delay on the dv88+ its says in menu not aplicable
    cheers for anyhelp
  2. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    Jmack -
    You don't need to turn it on on the 88 Plus/89 - if you use the player in PS mode the necessary audio delay is applied automatically.
    The menu line is when/if you have the optional Silicon Image PS board fitted in the 88/88Plus player and, of course, all DV27s; since the player can then put out interlaced and progressive video simultaneously you then need the menu option of PS delay or not.
    HTH.
    John Dawson (Arcam)
  3. jmack
    jmack
    thank you john
    only had it an hour
    what is the latest firmware and drive ware
    and how do i change the warranty over to myself
  4. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    Drive firmware should be 7.5 or 7.6 - the latter includes a fix for cactus datashield copy protected so called "CDs".
    Player software is 3.9.0 or 4.0.0 - the latter includes a fix for DVD-A capable players, they are identical for 2 channel units. The previous 2 channel release prior to this was 3.0.0 and most of the changes after this are to do with 6 channel players. If you have anything earlier than 3.0.0 it is worth getting the player SW upgraded IMO.
    For registering the product as a second owner (I assume you are a second owner?) please do so on line from the website, mentioning where you got it from on the registration form, or send an email to nadinec@arcam.co.uk with all the details.
    HTH.
    John Dawson (Arcam)
  5. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,117
    83
    Over the Hill & Far Away
    +119
    Hi...
    Any interesting updates for us DV88+ owners in the 3.9.0 software that makes it worth upgrading to ?
    Matt
  6. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    Hi Matt - I don't have the info at home here, but as I said above if you have 3.0.0 or later I doubt it is worth it. There are useful improvements / bug fixes if you have earlier SW.
    John Dawson (Arcam)
