dv79 software update
Discussion in 'Arcam Owners' Forum' started by hawk28, Jan 3, 2005.
Tags:
  1. hawk28
    hawk28
    I have recently purchased the dv79
    my question is should I update the firmware from 5.8 to 5.13?
  2. rimibar
    rimibar
    May 17, 2003
    463
    Cambridge
    +10
    Ever so slightly :offtopic: so apologies in advance!
    How do you view the firmware version that is currently installed?
  3. hawk28
    hawk28
    when you turn on the dv79 the firmware version appears for a second on the upper left of the view screen
  4. rimibar
    rimibar
    May 17, 2003
    463
    Cambridge
    +10
    I have an "automatically" detecting projector. So it takes a few seconds for the PJ to find the signal - by that time I don't see anything. Any other way of doing it?
    Thanks!
  5. hawk28
    hawk28
    yes there is, the first way I think is (I don't have a PJ but I'll try) switch the channel on the PJ where you usually see movies that way you probably wont have to wait and try turning off the automatic detection.,
    the second way is when you have the arcam logo try the numbers 4792 if that doesn't work try pressing setup first and then 4792, in the mean time I'll try and find out for you.
  6. rimibar
    rimibar
    May 17, 2003
    463
    Cambridge
    +10
    Thanks Hawk, I'll give that a whirl!
