DV79 - S/PDIF - comes from which chip?
Discussion in 'Arcam Owners' Forum' started by AlecF, Sep 5, 2005.
Tags:
  1. AlecF
    AlecF
    Hi, I'm thinking of using the DV79 solely as a transport.
    Does anyone know, is the S/PDIF driven by the Zoran or from the Wolfson?
    Is there any way of getting an I2S out of the unit?
    Has anyone used it as a transport? How's the jitter / performance?
  2. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    It is a great transort, with low jitter, VERY. Well sorted out design in my book, probably class leading upto £1.5k.
    I am not sure which chip does the SPDIF output in the 79, is it important? Do you need it for a DAC input?
    I2S is notruously difficult to get out of anything but there is some capability to hack into the 79 main boards but it is well optimised already. I wouldn't.
  3. AlecF
    AlecF
    Thanks, Nick, yes, I was going to run with a DAC.
    It could be important which drives the S/PDIF; especially as I've read some DVD players resample in DSP before sending to the digital output :eek:
    I presume the Arcam wouldn't do that, but perhaps John Dawson could clarify there.
