Dv79 Or Fmj 27a???
Discussion in 'Arcam Owners' Forum' started by highlander_777, Oct 12, 2004.
Tags:
  1. highlander_777
    highlander_777
    Apr 4, 2004
    216
    which one would you choose if you had the option? :lease:
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,565
    Edinburgh
    +1,265
    Depends if I was going to use a HDMI enabled display device. If so then I would probably go for the DV79. The only exception to this would be if audio performance was high on the list of priorities, in that case then the FMJ model would win hands down.
  3. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
  4. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    The DV27 sounds much better than the DV88, I never heard the DV79, but if it is in the same league, then I would Pick the FMJ any day, image comes second, everyone hears a lot more music than watches movies, at least I do...
  5. Neo X
    Neo X
    Vonhosen,
    Thanks for your info. :thumbsup:
    I just had a friend of mine from Birmingham to pick up one for me and sent it to Portugal. Lets hope all goes well will the transportation. :D
  6. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    Glad to help :)
  7. General Skanky
    General Skanky
    Jul 28, 2000
    4,247
    71
    +43
    You can get the same deal via www.pjhifi.co.uk who by the way will also sdi mod it in the future too should you need.
    Good bunch you can rely on.
  8. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    Congratulations, good buy, let me know how it sounds in your system, I want to hear it one of this days... :thumbsup:
  9. Neo X
    Neo X
    Guys,
    Yesterday, got my DV27A and had my 1st impressions about it: UAU!!!
    What a piece of machine! CD playback's amazing. DVD audiophile. I can't vouch for the Video as I only have a CRT and I didn't find many diferences.
  10. mutley
    mutley
    Jul 28, 2002
    450
    Portugal
    EVERYONE?
    That's quite an assumption!!!!
    Not me!
    Image comes first. 230cm of diagonal first!!!!!!!
  11. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    I said: everyone hears a lot more music than watches movies
    Not that sound is more important to everyone... :p
    Now, I bet even you listen a lot more to music than watch movies... :rolleyes:
  12. mutley
    mutley
    Jul 28, 2002
    450
    Portugal
    You said that and suggested the other.
    Either way, don't bet on things you're going to loose.
    I watch much more movies than i listen to music. But much much more!
    So Everyone still is quite an assumption.
    And i would say (not betting ;) ) that whoever has a PJ will tell you the same.
    P.S. I hate not being able to post smilies in this PC... It looks like i'm being too serious when i'm not...
  13. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    Unless you have a dedicated AV room, and I think you dont, I still bet that you have some music playing, even as background, more than movies, or do you dinner, and read, and entretain guests, watching movies... :eek:
  14. kraal
    kraal
    Aug 23, 2004
    103
    Portugal
    Congratulation.
    :offtopic: In your photo, it only lacks the identification card :D change it to the arabian... :lesson:
  15. mutley
    mutley
    Jul 28, 2002
    450
    Portugal
    NO. Football usually! :D
  16. Radioactive__Man
    Radioactive__Man
    Jan 13, 2001
    967
    Scotland
    +18
    just compared component output and HDMI on my DV79 hooked up to my Pioneer 435XDE, couldn't tell the difference at 625p, I'd go for the superior audio if I had the choice again
  17. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    OK... I give up... You have a TV in your car than, instead of a radio... :suicide:
  18. mutley
    mutley
    Jul 28, 2002
    450
    Portugal
    You HAVE to give up! :devil:
    I dont even put the antenna on the car, cause i never listen to radio and don't want to get it robbbed ;) . Also my radio is a front loader cd player it broke very quickly with copied discs made at home (i have the originals!!!).
    When i do listen to radio is for 30 min in the morning and it's mainly talking (manhãs da antena 3). And not in my car.
    Only time i listen to music is sometimes at bedtime (no longer than 60min).
    I it's a small fashionable player. So in my living room i almost don't listen to music neither i watch concerts. I even sold my CD player cause it had 3/4 months and only a couple of hours of play :nono:
    So, GIVE UP! :D
  19. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    OK, I forgot you are a dog, not a person... :p
  20. newbiebie
    newbiebie
    Mar 17, 2005
    81
    London
    Old thread but question if anyone still looking. Can I still get an SDI mod done for a 27A please and where? How much does this cost?
  21. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
  22. mutley
    mutley
    Jul 28, 2002
    450
    Portugal
    talk to pjhifi.
