Quantcast
Dv79 Hdmi
A
Alex-1701
Hi there,
I am in the fortunate position of setting up a system pretty much from scratch. I am trying to choose between Denon (AVR 3805 + A11), Pioneer (AX5i + 868i), or Arcam (AVR300 + DV79).
Because I am planning of putting the together with a projector I am particularly interested in each of these sets because of their HDMI link. However, the Denon A11 spec sheet says that thier player will only work with an HDCP compiant display. This rather limits my choices of projector. I am particularly keen on the Panasonic 500 or Sanyo Z2 projectors at the moment, and ideally would like an AV system that doesn't have any problems in terms of HDMI compatability.
Will the DV79 hav
A
Alex-1701
Oops ... don't know what I did just then. I seem to have acidentally posted an unfinished message.
Will the DV79 have any HDCP related comaptability problems in the same way that Denon do? If so, could anyone recommend a suitable match?
Thanks.
John Dawson
All HDMI players, including the Pioneers, will implement HDCP (the content protection algorithm) on copy protected DVDs - i.e. nearly all DVDs.
It is in the DVD player manufacturing licensing rules (specifically the CSS license) so there is no way round this. You must get a display that is HDCP compliant - all HDMI displays will be compliant and some but not all DVI displays. If in doubt check with the display manufacturer.
In my opinion it would be short sighted to buy an non HDCP compliant display as any future source devices (set top boxes etc) will also very likely implement HDCP on at least some content.
HTH.
John Dawson (Arcam)
hemp3
Is the dv79 available now? What would you have an DV79 or standard component dv89(available for £550)
John Dawson
The DV79 is now shipping and I would expect most UK dealers to have it within the next one to two weeks.
DV89s at anything like the kind of price you mention are clearly a bargain and if you don't want HDMI are exceptional value.
John Dawson (Arcam)
hemp3
I know this is subjective John but would a HDMI enabled dvd79 look better than a dv89 on a Pioneer 504hde
hemp3
Think I will go for one of these apparently Creative audio in Shropshire are doing them for £850 but I dont fancy the 300 mile round trip from london.
